Uninstal a driver and reinstall the new driver or reinstall samsung universal printer driver 2 or 3,or try change in the existing driver the protocol language.
Dear Its related to fusser temp. Check the fusser assy. thermostat it may open . either it may reset or replaced with new one. The error code mean-OPEN HEAT ERROR.
thanks
This error is a fuser malfunction. You will need to replace the fuser unit in order to get this running again. A fuser unit will run about $90 for a refurbished unit. You should check the manual for more error codes: Samsung SCX 5635FN Manual
The Samsung printer error code u1-2320 is related to fuser that means the fuser unit fails. Need not to worry; this error can be encountered by many Samsung printer users. ... The Samsung printer error code u1-2320 is also the fuser error; this might be resolved just simply power off the printer.3
if it's a vertical line in scanned pictures, it's probably a dust bunny on the scanner head, if it's only on printed pages, it's probably a dust bunny on or in the laser assembly or between the laser and the photosensitive drum. if cleaning doesn't get rid of it, you could have a defective scanner head or laser assembly, or a scratch on the photosensitive drum.
