SOURCE: i need to rewire a 239 volt motor to 120 volts.
There should be a wire diagram on the motor tag or under the coverplate. Eric
SOURCE: i have a 60 gallon vertical air compressor and it
check your running and starting capacitor. you may want to check your bearing to
SOURCE: i need to convert my 220 wiring back to 110 on my
There should be a plate where the ires run thru, and on the plate or motor itself, there should be a diagram shouwing what terminals to connect the leads too.
Hope this helps.
SOURCE: How do you wire a dayton electric unit heater?
tengo un motor dayton y nesesito darle un mantenimiento me podrian fasilitar un manual de ma
