Trying to get rid of Unistim firmware and get SIP Firmware. I have no Switch nor a PBX. Thanks!
SOURCE: Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server
* put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp
wri net
conf t
ca save all
copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm
copy tftp://your tftp server ip/pdm-304.bin flash:pdm
*** if this is a failover pair, upgrade the other pair
reboot
SOURCE: Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
SOURCE: Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
SOURCE: 1140E phone upgrade
C1B is ancient UNIStim firmware. You cannot downgrade to it. Try converting to a more recent UNIStim version. You can download firmware from www.nortel.com/support.
