Where it is flashing colors on the tv. How do I get it back to regular view. And I do not have the televisions remote.
SOURCE: Daewoo TV Question
there should be some buttons provided on the dash board of your tv... just enter the menu using those buttons n reset it back to the original settings
SOURCE: Proscan TV Manual
I have a Proscan model # PS36800HRJX1 and having a hard time putting it on DVD mode to be able to play a movie. I just bought a remote for it and can't figure out what's the problem. How do I go about it?
SOURCE: Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
SOURCE: Remote Contol Codes for Lloyds brand Television
lloyd's lcd1932wb - i need info for setting up my universal remote. i dont know which category (tv, cable, vcr or aux) do choose for setting this flat screen and i cant seem to find the code doing a manual search? does anybody know if theres a 4-digit code to program my universal remote? i hav try'd manually searching but i just cant figure this one out?... its frusterating... could someone please help me? thanx
SOURCE: Remote codes for a cable STB Explorer 3200 cable box and a Prive 26" TV
i need a code for my cable box that enables it so i can watch tv or go on demand
The UF4-200C is already programmed to control Motorola (formerly) General Instrument DCT1000,
DCT1200, and DCT2000 cable boxes. To control another device, look for the list of manufacturers'
three-digit codes for the device type in the Television Codes, VCR Codes sections, or Cable and Aux
Codes sections, then perform the following steps.
On the remote control, press and hold the appropriate mode key until the four mode
keys flash twice. The mode key will continue to flash.
Enter the three-digit code.
After you press the first digit, the mode key should light and stay on. After you press
the last digit, the mode key should flash three times and turn off.
If the mode key does not flash three times before turning off, the code is invalid for
this device type. Repeat the procedure with another device code.
Point the remote at the device and press POWER. If the device turns on or off, you
have finished programming.
If you have tried all the codes listed for the manufacturer and the device does not
respond, refer to the CodeScan™ section later in this manual.
More details are available with its manual you get with it.
OK.
