I have tried two seperate chargers with the same result but find it supspicious that both batteries are suffering the same issue at the same time particularly when they haven't been worked hard.
SOURCE: Dewalt charger problem
its the battery problem not the charger.don`t forget to bring your receipt for warranty. no question ask.
SOURCE: de walt de9118 charger
when charger is plug in to ac it will blink once.normal voltage out for the unit in between 36v to 55 volt. the reading u have is normal.
SOURCE: works off mains and battery but wont charge battery.
replaced the circuit board where it meets the battery
SOURCE: Can't charge the battery
I didn't have the time to find out what was the problem cause i needed the camera immediately so i bought a new battery and a new charger.Thanks for the help!!
SOURCE: Have just got the Dewalt DE9116 charger.Plugged it
that is normal it happens when u plugged and unpluged. after a second it should show no blinking. then when u insert the battery pack it would show the diagnostics. with the blinking pattern.
if you need the manual , you can get at www.dewalt.com or call us at 407 657 0474 and we can fax it to you.
