SOURCE: 42LC2DR
You need to press the button on the top right of the control ( the TV button) once and that will allow you to control the tv once again. Problem occurs when you accidently push VCR or DVD button which means remote control will try a different frequency to operate a VCR or DVD that isn't there. Hope this helps.
SOURCE: low to no signal strength
Try agusting the wirless properties for your wirless card. You will need to go uder start then go to conect to and the show all conecsions. The you will need to right clcik on the wirless conecsion and go to properties. Now you will click the button that says configure. I hope this helps
SOURCE: NO DTV CHANNELS
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
SOURCE: Can't view my digital channels
Get an outdoor antenna. Digital signals very rarely reach indoor antennas unless you are within ten miles of the signal origin.
SOURCE: belkin g wireless weak signal ,how to increase
Belkin, the worst router on the market. is a pice of junk !
Kevlar 29 (created in the early 70's) is the first generation bullet
proof resistant fibers and Kevlar 129 (created in 1988) is second generation
bullet proof resistant fibers. The 2nd generation fibers provide
more protection capabilities against high energy rounds.
