The water tank has a float magnet in the left hand side of the tank. A reed switch is mounted inside the machines right hand panel which senses if the tank is empty. If you remove the tank and fill with water and the display indicates fill tank. The sensor may have failed. Or the float has stuck in the down possition.If the display indicated filll sytem and or rinse. Then the sensor is fine. The next stage is to try rinsing . If it keeps saying filll system or rinse then there may be a blockage in the tank. Or the flow meters have failed. This is assuming water is being dispensed from the water arm etc . If no water is being dispensed and this time assuming you can hear the pumps running. Then there possibly be a blockage in a thermoblock. I could go on for ever guessiing based on the info you discribed. If any more info is required please say
Testimonial: "Thank you! It now works... :)"
SOURCE: Franke coffee system, always same error message ''fill water tank''
What you would have to do is take the side panel off to get at the solenoid. It is probably sticking closed and not letting the water fill into the boiler.
SOURCE: system fill message
I had a new Flair. The technician directed me to use a full bottle of the descale fluid and cycle the rinse button several times then to let it rest for 15 minutes or so. This was repeated for several iterations....It worked and I'm having no problems.
