Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the "hour." Minutes will reset to 00. If
the display shows over "30" minutes when you do this, the time
will advance one hour.
Or you can ge tthe manual on the link below.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDE9843.PDF
1 Press MENU to select SETUP.
2 Press or > to select the CLOCK mode.
3 Turn the Rotary encoder to adjust the hours.
4 When the hour has been adjusted, press the
Rotary encoder.
5 Turn the Rotary encoder to adjust the minutes.
6 When the minute has been adjusted, press the
Rotary encoder.
7 When the setting has been completed, press
MENU to select RETURN.
The unit returns to normal mode.
Pressing and holding MENU for at least 2 seconds will
return to normal mode.
1 In the Clock priority mode, press and hold the DISP/
TITLE button for at least 3 seconds while the time is
displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the
3 When the hour has been adjusted, press the Rotary
encoder.
4 Turn the Rotary encoder to adjust the minutes while
the time indication is blinking. The time is automatically
set 5 seconds after the minute adjustment. The time
can also be manually set by pressing the Rotary
encoder.
If you need the manual is on the link below page 6 tells you how.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9805.PDF
Good Luck
