Building Materials Logo
R
Ray Fowler Posted on Jul 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Stanley garage door opener model 8500. I replaced the door and now my operate button doesn't work. Is there a reset?
Steve Pack
Level 3:
  • Building Mat... Master 7,121 Answers
  • Posted on Jul 24, 2017
Steve Pack
Level 3:
Answers
7121
Questions
Helped
2272813
Points
27904
If the door is heaver than the original you may to adjust the opening force and the closing force. Check your instructions. The closest gdo I found was a chamberlain 8500. Go online to
Elite Series 8500 Garage Door Openers LiftMaster and see if this the same unit. The instructions can viewed . Good Luck
5 Related Answers
Anonymous
  • Posted on Jul 24, 2008
SOURCE: Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
Anonymous
  • 30 Answers
  • Posted on Feb 10, 2009
SOURCE: i installed a model hd900d
My best advise to you is get the brand name remote for your opener. I know it sounds like a pain but click brands are not super great because there supposed to work for many different kinda. For the most part you can call your local garage door dealer and pick one up for your opener. They may sell you a lift master brand opener which is find sears/liftmaster/chamberlain are all the same. Should only be about 35 bucks if you pick it up
Anonymous
  • Posted on Apr 26, 2009
SOURCE: have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
Anonymous
  • Posted on Sep 21, 2009
SOURCE: Sears garage door opener
I just found the solution for my 'ancient' Sears garage door opener, model # 139.655000, and I figured I'd share it.
There's a separate radio module, wired to the main opener. This module is small, has a short wire/antenna, and plugs directly into an outlet.
There's a manual open/close button on this module (I didn't realize this until I got up on a ladder). This button is also a removable cover; underneath it is a "smart actuate" button -- this is your learn button.
What I did was: unplug the radio module. Pry off the cover. Plug the radio module back in. Hold down the button on the remote. Press the "smart actuate" button. This programmed my remote successfully!
freddy51
  • 3 Answers
  • Posted on Feb 08, 2010
SOURCE: remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
Stanley garage door opener model 440. need a manual
http://www.teknuw.com/garage-door-opener-installation-manual/stanley/
https://www.manualslib.com/products/Stanley-U-Install-3760134.html
If you can identify the model number, it may be possible to locate a manual from 1997 using the internet with http://www.google.com
According to one of the web sites above, "Stanley stopped making garage door openers and gate operators in 1997. Spare parts can be difficult to find however original and compatible remote controls are still widely available, most of the remote controls used by Stanley were manufactured by the Linear corporation.
Stanley made garage door openers for other companies and many parts are interchangeable some of the brands they manufactured for are Vemco, U-Install, Quiet Glide, Light Maker, Home Innovative, Whistler, Popular Mechanics, and Secure Code."
https://www.justanswer.com/home-improvement/7enbn-stanley-garage-door-opener-model-440-51-garage-two.html
Wireless garage door opener works wired one doesn,t
Either the wall control has gone bad or you have a broken wire going to it.
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
Programming my 98 blazers Garage door button on dash to a stanley
Here is some programming info for the Stanley.
http://www.aaaremotes.com/standualcodl.html
The programming information for your Blazer should be in the owners manual.
I have a stanley garage door opener that won't close the door
the door beams are not working properly. Let me know what you find
4helpful
4answers
Reset garage door code
Hi, The opener, remotes and keypads have a set of dip switches that you can use to change the code. You will find the switches when you open the remotes and keypad and are in the back cover ( depending on the model) of the opener itself. Make sure that the codes of all the switches are set exactly the same. If you need additional help let me know! Good Luck.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Top Building Materials Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Building Material Expert? Answer questions, earn points and help others
