Hi, my nokia 6300 got a flat battery while using the internet and switched off. So as you would expect i grabbed the charger and plugged it in and when it started charging i went to turn it back on and now dosn't start it just comes on for about 2 seconds and then goes off, it will do this 3 times in a row then just stops. i take the sim card out and turn it on with out it and it gets to the bit where it asks you if you want to turn on without the sim, so i press accept and then turns on and off again a few times and then stops........Helppppp!
Initially u have to remove the sim card and the battery. Once u have removed insert only the battery and put to charge for 10 to 15 mins. then remove the mobile from charger and insert the sim card. Now after 30 sec switch it on.U will be able to do the process
Try removing the sim and memory cards then try to switch it on, whilst the charger is plugged in. If it still fails then it does need to go away for repair.
