SOURCE: sharp ar-5316
Hi, from memory, the secret test commands are: # I CA #, then 81 to reset main copy count.
Cheers
Andy
SOURCE: AR-5127 Counter Reset
Try these steps
1.Press continously #key then Interrupt key then CA key then #
key
2.If the display turns off it means
that you are inside the simulation but if not do again step 1.
3.Press 81 then press enter then press 1 then enter
Hope that this will help to reset .
SOURCE: Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
SOURCE: how do i reset the printer counter on a Sharp
Simulation 24-9 Used to clear print mode counter
SOURCE: I need to reset copy
Perform the following procedure to enter the simulation mode."#" key Interrupt key "C" key Interrupt key, then, then enter 24 start 7 start, then you can clear the drum count.Press 42, start, 01, start for clearing developer counter, and after clearing all this you have to press 'ca' to exit this mode, rate this and vote for this.
Testimonial: "Drum counter successfully reset. Thanks a lot."
