With our old clock when the chimes got off, we would advance the clock hands 3 hours while NOT allowing the clock to chime any of the hours or half-hours.
SOURCE: atomic clock sky scan model 87801
Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time. kindly gave your rating after you read this.
SOURCE: Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
SOURCE: athletic works watch owners manual
if you press both buttons on the right at the same time it might work. Im not sure if it will for ur model, but it worked for mine =)
SOURCE: How do you syncronize the chimes to the actual
Are the hands held on by a nut? usually you can remove the nut with your fingers or a pair of pliers wrapped in cloth or duct tape to prevent scratching.
Before removing turn the minute hand (minute hand only and clockwise only; do not manually turn the hour hand and never counter-clockwise) turn the minute hand clockwise until it chimes at an hour mark.
Then remove the hands and and place them pointing to the correct time.
If you are uncomfortable with this I recommend taking it to a clock shop or jeweler that sells clocks. If it is inherited, it may need some maintainence (oiling and regulating) anyway.
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
