SOURCE: This set only has 5 Watt output, can this be lifted to 10 Watts
The only way you will boost the audio output would be to hook up an external amplifier to audio outputs on the back of the TV. Doing ANY modifications to the audio circuit may leave you with a TV that no longer works since it was designed to work with the amplifier circuit that's already in the TV.
SOURCE: Replacement of Light globe in Ice Dispenser
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
SOURCE: Replacement Light Globe for Ice Dispenser
Your local a/c supply may have it or can order one for you.
SOURCE: refurbished galaxy 949 - blinks on and off when
make sure you have enough amperage going to the radio. take 12v/wattage= amps.. 12volts/4watts=3amps.. if your using cigarette socket for power make sure it has enough amps. some newer vehicles do not have it on those sockets.. some have extra auxillary sockets that are 5-10amps.. try running a long wire for 12vots straight to battery. both + and - and see if it flickers... if not prob is in your wiring.. if it still does.. then its the radio. take it to a good cb shop they should test it for FREE to tell you the prob...
