Appliance repair serves Memphis and surrounding areas for appliance repair services for washers, dryers, dishwashers, ovens, refrigerators & more! Check out our website for more information https://Appliancerepairmemphistn.com
SOURCE: Maytag NMPEB08F2A Portable Air Conditioner
I have the same problem w/ a window unit - fedders unit under the Maytag brand. No idea how to fix it, but would be great to get some info on this.
SOURCE: My CV-13NH portable type room
If its blowing air, but not cold, the compressor isn't engaging. There are many different possibilities on this.
Bad compressor, unit out of gas, bad run capacitor, etc, all could cause this, even a bad control panel.
Hope its something simple.
Greg.
SOURCE: remington 60 portable forced air heater 60,000 btu
I had the same problem. I took the nozzle head off and blew through it with air. I also blew through the air line, this is the one that goes to motor. It has worked fine ever since.
SOURCE: air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
SOURCE: Everstar mpm08cr bb4 will cool briefly then briefly blow hot air
check your filter and replace,, and that dont do it,, you need to clean coils,, and if that dont work it may be low in gas,, hope this help you
