Steam runs non stop until that tank is dry.
Rowenta irons have a propensity for leaking. Most users do not add water to the tank but instead use a spritz bottle to dampen the fabric and then use the dry iron.
Testimonial: "That does not help. It isn't leaking it is steam."
Just let it steam itself dry and then don't add water to the tank. Use the iron dry--no water.
I use this iron a lot for the steam feature. Dry is not an option.
Then you may look for another iron.
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
SOURCE: no steam coming out and water tank not pumping water into generator to make steam
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
SOURCE: Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
SOURCE: won't steam
I know it's a silly question but are you pressing the trigger in the handle? If you are then the solenoid valve may have failed
