SOURCE: Service Charging System
DONT START THE CAR///IGNITION ON//PRESS THE GAS PEDAL DOWN 3 TIMES SLOWLY//THEN START THE CAR. THAT RESETS THE COMPUTER AND THE CHARGING SYSTEM WARNING LIGHT.
SOURCE: After charging overnight, Roomba only runs about
Reset the Roomba by removing it from the charger, then holding "spot" and "dock" for about twelve seconds. When you let go, the unit will play an ascending series of notes. Then recharge it overnight. If the run time is still short, give Customer Support a call-- be sure to have the Roomba with you when you do.
SOURCE: Controller has no voltage output when connected to fence
You have a dead short to ground somewhere along the fence circuit.Disconnect the leads again,and use a resistance checker to check resistance to ground.(Push a metal rod into the ground to connect one of your leads to,and connect the other lead to the fence.)One or the other fence circuit ends will have a lower resistance to ground.That fence end is closer to the short to ground.Follow that part of the circuit until the resistance to ground is as close to zero as you can find.(taking the ground rod with you as you go)Somewhere in that area you will find your short.
SOURCE: FIRING ORDER 1984 ROLLS ROYCE SILVER SPUR DIAGRAM
Right Bank A, Left Bank B A1 B1 A4 B4 B2 A3 B3 A2
SOURCE: I HAVE DEWALT CHARGER DE9116.ITS OUT PUT VOLTAGE
check output voltage on charger label most chargers are not regulated so if it says 18 volt output it may put out 24 volts but if its putting out 51 volts it may have a short batteries will get warm but not hot replace charger
