Washing Machines Logo
M
Maree Jeanette McTaggart Posted on Jul 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does error E40 mean - Washing Machines
Steve P
Level 3:
  • Master 3,912 Answers
  • Posted on Jul 16, 2017
Steve P
Master
Level 3:
Answers
3912
Questions
5
Helped
1307698
Points
15904
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
2 Related Answers
Anonymous
  • 35 Answers
  • Posted on Apr 04, 2008
SOURCE: error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
ifawnmeade
  • 266 Answers
  • Posted on Mar 08, 2014
SOURCE: WHAT IS ERROR E40 MEAN?
Its a defective door lock. It might have to be replaced by a techie! Hope its under warranty
Built in machine. It show error e40. What does it meant
Hello Monica, thank you for your post!
Based off the information you have provided your Electrolux washer is displaying an error code of “E40”. I am showing that an “E40” error code means this could be an issue with your door swicth or main control board. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If you continue to receive the error code once power has been restored you may need to seek assistance from a professional technician for a proper diagnosis. Hopefully this information is helpful to you. –Matt
My ricoh ft4615 have an error E40. what does it mean??
E40 means that you have an open thermistor, which needs to be replaced.
15helpful
Error code e40 on my washing machine electrolux ewn 16781 w
The Error E40 warning means the door is not properly closed. The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Thank you for contacting Fixya.com
14helpful
2answers
Electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
4helpful
Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
1helpful
I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
3helpful
Error`E40
Top Washing Machines Experts
john h
