I can't turn on the wi-fi radio, so will probably have to take it somewhere.
SOURCE: Want Instant wi fi when turning on my laptop
Hp comes with a wi-fi utility and I dont find it very useful, so first, you might want to uninstall the software from add or remove programs and then use windows to manage your wi-fi.
Once you connect to a wireless network from 'network connections', it will automatically be set to default and should connect at the computer startup.
If it does not connect automatically.go to 'change order of prefered networks' and put your prefered network on top and set to automatically.
SOURCE: can not enable wi fi on desktop
the best way i have found to wifi a desktop is a usb wifi stick there cheep. all mine are wireless with usb sticks.pop cd in run it put usb drive in when promted and youll have wifi
SOURCE: wi-fi
Please make sure the drivers for your wireless network adapter is installed.
1) go to Device manager - rightl click on my computer and click on properties, select HARDWARE tab then click on Device manager
2) See if the wireless adapter is displayed under Network adapters. If there is an yellow exclamation mark on the Network adapter, it means the drivers for your adapter are not installed.
3) If you find the drivers ok, then make sure that the wireless radio button is turned on. Usually the wireless radio can enabled or disabled from a tray Icon on right side of the system. Most of the system also come with a on/off switch for the wireless radio which is basically on the front side of the laptop.
If the above does not help please revert with the model number of your system and I will try some other steps for you
Testimonial: "thanks very very much:)"
SOURCE: acer aspire 3000 wi fi problem
First you need to make sure the Wireless drivers are installed in the computer, aswell the Acer Related utilities. Then Most acer laptops have a button on one of the sides or on the top of the laptop to turn on the wireless.
To find out if you have the acer related programs installed, try pressing some of the buttons on the top of the laptop, that are NOT apart of the keyboard, they should open up acer or related programs, if noting happens the programs are not installed, one of the buttons is likely to turn on the wireless.
To check if the wireless drivers are installed press start -> run -> type: msinfo32 (OR press down the windows key and press R, then let go and type msinfo32 into the run menu that comes up and click OK)
On the program, left side, open up components from the + next to it, then find Problem devices from the list and click on it, on the right you will see a list of devices that are not installed or not working.
If the list is empty, everything is properly installed. and you should be able to get your wireless to turn on by pressing on the wireless button on the laptop, and then use your computer to connect to a wireless network.
If you need further assistance let me know.
SOURCE: wi fi button
Look carefully on your "Function" keys example, F1, F2, F3 to F12 that are located above your keyboard. On each function keys, there is an icon. One of those is wi-fi. Find which function key has the wi-fi icon then find key to activate those functions. It is called "Fn" key (located in the bottom of your keyboard near "Ctrl" or "Alt"). Now press and hold "Fn" + "F#" then release. This should turn on your wi-fi. On mine, I have wi-fi on "F8" so I would press "Fn" + "F8".
I bought an MSI L1350 Netbook with a standard second-generation Intel N450 Atom processor for $230 last weekend which has an additional $30 rebate. The Ralink 802.11 b/g/n mini PCI-E adapter that comes with the netbook has some very buggy drivers that cause Wi-Fi to intermittently disconnect or fail to find any network. An even bigger problem is the fact that its drivers seem to cause Windows 7 to completely hang requiring a hard reboot.
I have found a solution that seems to have fixed the random Wi-Fi problems by updating to the latest Ralink drivers posted in March of 2010. The system hasn't hanged due to Wi-Fi drivers in two weeks now. These are signed drivers so they are legitimate and you will not get a certificate warning. If you happen to own this netbook or something with a similar network adapter, I would highly recommend updating the drivers. It's generally a good idea to update all your drivers anyways.
Another problem I've found is the Intel 3150 graphics driver blue screen of death when trying to launch Adobe Flash Media Live Encoder 3.1 (which is a very good free video capture and encoder software that allows you to broadcast high quality directly to sites like Ustream). This problem affects all netbooks with the N450 CPU. The only way to fix this was to update the Intel 3150 integrated graphics driver and you can obtain a copy of it here on Intel's site.
It sucks to have to get a consumer product that crashes so badly out of the box. It's even hard for me to handle and I can't imagine the frustration that normal users would have. This blog post should help you a lot if you managed to land here after googling these problems.
