Computers & Internet Logo
Jaimee Taylor Posted on Jul 15, 2017
I have a 236v6 monitor and are using a belkin HDMI cord, how do i access the functions on the moitor to ensure the HDMI option has been chosen?
2 Related Answers
Anonymous
  • 811 Answers
  • Posted on Apr 06, 2011
SOURCE: I have a 22", 1680 x 1050 HDMI Gateway monitor
Go to Amazon.com they have everything that you could possibly need as far as cables and great prices as well just type in the search product box what type of cable you are looking for and it will come up. You will not find anything cheaper anywhere else for computer stuff as far as cables and adapters.
Or go to a local Bestbuy if you have one in your area and they can assist you with cables any local computer shop can assist you. Thanks for using FixYa John
Anonymous
  • Posted on Jul 06, 2011
SOURCE: Can I hookI hook up
Most Acer laptops have a Blue VGA Port for external monitor hookup. Does your TV aslo have such a port (most newer models should)? If so connect these and change display settings on Laptop.
2answers
How do I use my Samsung telephone for a Samsung P2350-1?
You can't. Your phone doesn't have an IR Transmitter and your Samsung TV is not a smart television connected to the internet.
Just buy a new Copy Facsimile Remote for the set for about $20.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
NOPE scrub all that, this isn't even a television, it is a computer monitor!! No chance for remote control of a computer monitor as it is controlled by the computer is is connected to. single channel single function, just a display of what is went to it.
https://www.google.com/search?q=samsung+p2350-1
Just purchased Asus VE248H monitor. Used a 10 pin connector and was happy, but wanted more. Hooked monitor to pc with an HDMI cable, got HDMI - NO SIGNAL. Screen went dark. Disconnected HDMI, reconnected...
Hi , just access the monitor on-screen display (OSD) menu and ensure Monitor input mode is configured for HDMI ( Asus speak the " desired input source" ) - Input select is accessed under tv with arrow icon : change from vga to hdmi
4helpful
I have no audio on P215H LCD Monitor
The audio cord is called HDMI, it's actually audio and video, now just because the monitor you have has a HDMI port does not mean your PC has one, you need a onboard video port that is HDMI or a graph card with HDMI.
Mostly good motherboards have HDMI or cards.
***** Now, the model you posted it does not have speakers so how do you except it to have audio ?
There would be HDMI on the monitor if it had speakers.
Can i use a power cord from a dell moitor i tried but i dont know if its the cord or moitor it was give to me without cord
It uses the same power cord as your PC, NEMA5-15P to IEC C13,
User manual:
http://www.viewsonic.com/assets/027/7939.pdf
It may have problem inside. See failed VIEWSONIC in my albums.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Can i use a computer monitor power cord to replace the xbox 360 AC power cord
Only if you shave the power cord to fit in the same shape as the xbox plug-in. If you succeed then it will work. Keep calling local Gamestops or EB's stores for a used power cord for about 29.99-39.99 in used price.
2answers
Wifi not function
My Internet service provider walked me through connecting correctly. I had chosen the WEP security options and should have chosen the WPA-PSK option. Call your service provider and get them to help verify your security access codes.
I want to use plasma tv as external monitor
Your laptop is not set to enable the external video output.
Most likely, your laptop has a key that says "RGB/LCD" or something similar on it. This key cycles through the various video output options, enabling the laptop's LCD, the external RGB output, or both simultaneously. Most laptops require you to hold down the function key ("FN") when pressing the "RGB/LCD" key to cycle through the options.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
