Question about The Computers & Internet
On a Bizerba 404-A what is the error code 212 mean. The repair guys have yes to fix it.
SOURCE:
  • 2072 Answers
SOURCE: Error codes on xerox 212
An E5 most frequently comes from the door connector . When you open the right side on the upper left there is a black connector. Those contacts may be dirty or bent. Carefully clean and reform if necessary. I will send you some other info to follow.
Also if you take the copy cartridge out and and clean all the contacts inside the machine you can see, it may also correct it.
Recurring problem with E5. Door connector has been replaced, contacts on Interconnect board are clean and shiny, but interlock connection still not reliable. When you remove the rear motor cover and press on the door connector, the E5 goes away and the fuser starts to warm up. The door connector is mounted loosely to the door to allow it to locate itself with the interconnect board when the door is closed. If it is too loose, the connector will not make good enough contact to complete the interlock circuit
Posted on Jan 25, 2008
Bubbabear64
  • 2794 Answers
SOURCE: how to repair sc690-02 error code on aficio 2232c
Loose connection in the Magenta section
1. Turn the main switch off and on.
2. Check the cable connection.
3. Replace the laser optics housing unit.
4. Replace the BCU board.
It should require a technician to take care of this for you.
Posted on Aug 20, 2008
tech435
  • 284 Answers
SOURCE: Error code 212
are you faxing from you computer . because this could cause the error
Posted on Sep 22, 2008
carloadrian
  • 571 Answers
SOURCE: i keep o n getting 404 not found error on my acer extensa 6630z is there anyway of fixing it
Are you reffering to a website error 404? You have two possible reasons for that:
1. The website is down
2. You have a slow internet connection.
Here are the things that you can do.
1. speed up your computer's internet connectivity.
2. Check your internet speed.
If you want to optimize your computer's performance, I suggest that you install Radarsync.
I hope this helps.
Posted on Dec 07, 2012
  • 10 Answers
SOURCE: What does error code 497 & 404 mean?
Error 404 generally means "File Not Found." Not sure about 497.
Posted on Jul 13, 2014
My innotab max keep giving an error message 404 which mean not connected to the internet but it is
I too have a InnoTab MAX children's tablet with same issue. Power cycling it, leaving cartridge plugged in/then out, have power plugged in then not, forgetting WiFi connection and re-linking after verifying WiFi is fine from other devices, also standing beside the wireless router all have been fruitless.
Having spent an hour on it last night and almost that long tonight - it's going back to BestBuy tomorrow. If I resolve the issue I'll pay what I did.
Dec 25, 2015 | Toys
What is error code 404 for Aspire 7741Z
404 means the page is missing. It either does not exist and the link you had to get there is faulty, or it cannot be downloaded.
Try F5 to refresh the browser page. If it still fails complain to the site owner.
Mar 01, 2015 | Aspire Computers & Internet
Google 404 that's an error What is 404?
A 404 error is an HTTP status code that means that the page you were trying to reach on a website couldn't be found on their server.
Technically, an Error 404 is a client-side error, implying that the error is your mistake, either because you typed the URL in wrong or the page has been moved or removed from the website and you should have known. Another possibility is if a website has moved a page or resource but did so without redirecting the old URL to the new one. When that happens, you'll receive a 404 error instead of being automatically routed to the new page.
Note: Microsoft IIS web servers sometimes give more specific information about the cause of 404 Not Found errors by suffixing a number after the 404 as in HTTP Error 404.3 - Not Found which means MIME type restriction.
Aug 28, 2014 | Acer Computers & Internet
Jul 13, 2014 | Office Equipment & Supplies
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
404 error
Try to retry the web page by pressing F5
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 06, 2012 | Acer Extensa 5630Z-322G16Mn Notebook
404 not found
The 404 or Not Found error message is a HTTP standard response code indicating that the client was able to communicate with the server, but the server could not find what was requested.
The web site hosting server will typically generate "404 - Not Found" web page, when users attempts to follow a broken or dead link, hence the 404 error is one of the most recognizable errors users can find on the web.
A 404 error should not be confused with "server not found" or similar errors, in which a connection to the destination server could not be made at all. A 404 error indicates that the requested resource may be available again in the future; however, the fact does not guarantee the same content.
Mar 11, 2012 | YouTube Computers & Internet
J8 Error Code
There are a few different part numbers for those cartridges, the chip on them bills differently.
A J8 means although you have a 212 cartridge, it has a chip on it that does not match your machine setup.
A J8 indicates a mismatch in the cartridges and the machine. No you do not have the wrong physical cartridge, it just has a different chip on it.
Nov 08, 2008 | Xerox 212 Laser Printer
Hi my Archos 404 has died....Recovery code error 2. I have tried everything... Sounds like I NEED A NEW ONE am I right Smilar
You _MIGHT_ be right, but first open your Archos and check for the loose HDD cable, as couple of guys had such issue.
Apr 28, 2008 | Archos 404 Digital Media Player
Computers & Internet Logo
413 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Fred Sops
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
