How do you have it hooked up, by coax, or RCA jacks! If coax Put TV on 3 or 4 if RCA Yellow, red, white jacks! ,make sure the yellow is in video in to TV and video out on box! both the box and TV jacks are color coded just match them up! but if You have in and out jacks on the TV, like I said make sure the yellow plug from box goes to to TV video in! One last thing, The TV could have more then one aux plugins, make sure TV is set to right one with your remote! Good Luck! Regards!
SOURCE: Number 2 in upper right hand corner of screen
Had this problem also when I rebooted my Time Warner Cable box. Unplug everything from the wall including power strip and wait 60 seconds then plug back in and turn everything back on. Worked for me and havent had a problem since. Time Warner does not know what causes this yet.
SOURCE: Connect to Converter Box
There are a fews ways of accomplishing this.
On the back of your converter box and TV/VCR there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from the antenna to the (IN) connection on the back of the converter box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the convert box.
Step 3. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful. Please take a moment to rate tis solution.
SOURCE: Zenith 60" Plasma - Black Void with color spikes in upper right corner....
why is there no answer to this question?
