Question about Pyramid Audio Players & Recorders
How to hook up a pyramid pro plus 4 channel pb-180px without using rca jacks for 6 by 9s
    Genius:
  • 1,114 Answers
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Posted on Jul 27, 2009
SOURCE:
Why does the red light come on when i hook the power wire up to my car amp?
Could be fried, or connections are wrong and its not getting a good ground. If you're not getting power most likely its fried. Check fuses etc. Take it to a brandsmart and have them test it
Aug 26, 2014 | Pyramid - America: 4 Channel 1800W America...
How Can you record tv show using a converter box
Hook the converter box cables to the input RCA jacks on the back of the VCR, then hook the output RCA jacks to the input RCA jacks to the TV, Keep the VCR on channel 3 or 4, on the TV in menu scroll through the source settings to find the what source the vcr is using
May 05, 2014 | GE Vg4261 Vhs Tape Vcr Plus 4 Head Hq...
Pyramid pb-230g
Use Ohms Law.
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
May 27, 2012 | Pyramid Car Audio & Video
How do i install a pyramid pb880 4 channel mosfet amplifier?
run rca cables and a remote wire from your radio to the amp,run a power wire from your battery and attatch a ground to the car ,then hook up the wires and cables to there respective places.
Jan 15, 2011 | Pyramid Car Audio & Video
Pyramid america 1800 watt amplifier has power but no sound. whats the problem?
It doesn't work.
Jan 02, 2011 | Pyramid - America: 4 Channel 1800W America...
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
Hi,just bought a 6x9 jbl gto937 speakers for my car,each speaker is 100watt rms and 300 max .Can anybody advice on what amplifier should i get for them?I know i can run them without any amp but think they...
Pyramid makes the PB series of amps. I have one that's driving a Sub.
The PB 700 puts out rms 60watts x 2 @ 2ohms, which gives you some "headroom" for your speakers. You don't want to over drive speakers with , for example, a 1000 watts for 100 watt speakers, because that's a good way to blow your speakers.
There are many brands and models of amps that will fit your speakers. Just make sure the amp will drive 2ohm speakers, since your jbl's are rated at 2ohm impedance.
You may want to consider adding a Sub woofer to your setup. A single Sub would fill in the low end very nicely. If you got a 4 channel amp, then two channels will drive your jbl's, and you can bridge the other two channels to drive the Sub. That would be a kick'n sound!
Just make sure the amp is bridgeable
For example, the Pyramid PB 1200 is a 4 channel, bridgeable amp. This particular amp will drive the 2ohm jbl's, but you would want a 4 or 8 ohm Sub connected to the bridged channels.
Jul 05, 2009 | JBL GTO937 Car Speaker
Connection for y pb pr cables
The color-coding used for the RCA connectors is nearly universal:
  • composite video - yellow
  • audio - red (right channel) and white (left channel)
  • component video - green (Y), blue (Pb) and red (Pr)
Also, these jacks are normally labeled in print as well, although it's sometimes hard to read the text on some equipment.
Match the connectors on your converter box to the corresponding connectors on the TV. If your converter box was one purchased with the $40 US Government coupon, it may not have the component video outputs. The only coupon-eligible boxes are the most basic models, and they sometimes have only RF (channel 3 or 4) and composite video outputs available.
May 03, 2009 | iLO 3200 32 in. LCD Television
326 people viewed this question
Top Pyramid Audio Players & Recorders Experts
 Grubhead
Grubhead
protojexxx
Dave Cowley
Dave Cowley
Level 1 Expert
Are you a Pyramid Audio Player and Recorder Expert? Answer questions, earn points and help others
