I want to see the attribution of the pins for the module
SOURCE: i am looking for a
Go to this website it may help you out .....
http://forums.evolutionm.net/lancer-audio-security/6686-here-instructions-installing-stereo-head-unit-5.html
SOURCE: Lancer 2002, change heater control switch
contrary to what the dealership tells you you don't have to take out the entire dash to fix the heater switch, all you have to do is first locate a heater switch which I thought was imposible to find too, but I found one online for 165 bucks from a used autoparts store, then all you do is take off the molding that surrounds your stereo, then take out your stereo, then you will see a blue cable on the right side and a black one on the left carefully disconnect those and the two wireing harnesses in the back the upper one is white the lower is black, then pull the unit out and put the other back in the same way, now it's still going to stick cause of those moron engineers so if you kneel on the ground and look next to your gas pedal you will see to pieces of white plastic that is why you can't switch to heat that flimsy cabel has to push that gear forward, that gear is sticky so it won't go forward, there is a replacement gear to fix that problem that should be about 18.00 from the dealership. it took me about an hour or less to do the whole operation. I just literally finished it 20 minutes ago in my wifes lancer which i broke that knob off of. Good luck if you havent figured it out yet.
Allen
SOURCE: Please help me i need the Lighting Control Module diagram
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm1of3.gif
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm2of3.gif
http://i28.photobucket.com/albums/c216/thomaspedemon/99lcm3of3.gif
follow the three links for complete wiring diagram of lcm
SOURCE: I hae a 2002 mitsubishi lancer I need wiring
Here is a link that should help you get the wiring colors you asked for. Good luck and hope this helps. http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
SOURCE: 2002 mitsubishi lancer es manual
eBay has these manuals available. Item # 270544305731
Sells for 6.99 to 7.99 + .99 for shipping.
This is the repair manual and is a CD for use with a PC.
They have owners manuals for some models too.
good luck
