SOURCE: frigidaire air conditioner
remove cover .It might have two screws on the side or just pops off. Pull unit out from cover. if it does't move remove screws in back of unit near condensor
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
SOURCE: How do I remove the
In order to do this, you need to have your air conditioner turned off, and then simply pull the tabs on the filter in an upward direction, and the screen type of filter just slides right out. You can wash the filter under hot soapy water, rinse and then just shake it dry. Replace the filter and turn your air conditioner on for a few minutes, and it's all dry.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
SOURCE: Electronic control on Frigidaire air conditioner not working
which one take live or nuetral ?
common
start
run
thanks
SOURCE: DUO THERM 590 QUICK COOL AIR CONDITIONER PART NEEDED INTAKE GRILL
you could contact the manufacturer of the rv and they can help you with you search. Hope this helps
Dave
