D
Daniel Forrester Posted on Jul 12, 2017
To open a Sony rm D.C. 400 remote
I need to clean the contacts
5 Related Answers
Anonymous
  • 579 Answers
  • Posted on Jan 08, 2008
SOURCE: Opening the case of a JVC Remote Control
Not having seen that particular one, remote cases usually have a couple screws under the battery to lock the case together and then a number of plastic tabs around the perimiter that hold the joint closed. find the screws (sometimes they hide them under labels) - I don't know what it is about screws that manufacturers don't like to show. Either think they are not cosmetic or don't want us take-it-apart maniacs to get in. Anyway, get the screws loose then (this is the hard part) carefully pry open the case joint, feeling where and how the tabs snap out and then be careful not to have everything inside go flying when the last one lets loose. Almost impossible to not leave little gouge marks in the joint.
Hope Ya Fis It!
A
Anonymous
  • Posted on Jun 19, 2008
SOURCE: Insignia TV code for Sony remote RM-V302
press tv, hold setup til tv blnks twice and release setup, type 10463 then power. 5 digit code not 4 like most.
Anonymous
  • Posted on Sep 09, 2009
SOURCE: Code for Sony RM-V310A remote.
How do I program sony universal remote RM-V310A for a polaroid flat screen TV
Anonymous
  • Posted on Dec 24, 2010
SOURCE: Sony remote RM-DX500 not working with Disc
There are 2 set's of command switch's for the dvd player, a 3 position command switch on the back side of the dvd player and another 3 position command switch on the inside of the remote right next to the batteries, easiest option is to remove batteries from remote and test each one of the 3 position switch's labeled 1,2 & 3 and test remote control.
Anonymous
  • Posted on Jan 02, 2011
SOURCE: how can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Hi, My sony remote failed recently Model
There is some locks on its upper and lower case. You can locate it by its side slits.
1helpful
Sony internet tv remote stuck
open the remote control and clean the keypads from dirty, corrosion, oxide, and bad contacts, with c. cleaner very well. with carefully.
2) replace a new battery with the same type:alkaline
3) clean the contacts batteries with c. cleaner
4) try again.
5) if the problem persist you have 2 options go to repair shop TV for fix it, or REPLACE IT.
God bless you
Open remote control sony RM-GA011 for cleaning
how can i open remote control RM-GA011 SONY REMOTE
I have an kv-27exr20 and the remote cut the speakers off how do i get it back on
reset the code and try again download from www.remotecodelist.com
or remotes.com and proceed according with common sense. Try to clean the contacts batteries b) retight the spring contacts batteries with a pliers for better contacts c) resolder the wires contact batteries. d) try open the rem.control from clean to dust, dirty, oxide, bad contacts or open contacts, and repair. Remember they send signal infrared from Syscon transmittter vs Syscon Receiver, the signal can be very clean.
God bless you
1helpful
Hi my name is Oscar I have a tv element model FLX-3211B and do not work the remote control codes sony RM-VZ320 and need help please!
Please reset the codes and try again. You must replace the batteries by new ones type alkaline b) clean the contacts batteries c) retight the spring contacts batteries with pliers d) open the remote control for clena the keypad switch from dirty, dust, oxide, bad contacts or open , remember they send infrared signal from Syscon to the microncontroler Receiver. see the blck..d
go to the next web pages, give your model, mark.
www.remotecodelist.com + remotes.com
God bless you
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
2helpful
3answers
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
20helpful
I need to separate the covers on a Sony TV Remote Control but there are no screws holding the covers together. Model no. RM-ED005 (R) Can you help?
At the bottom of your Sony RM--ED005 Remote control you'll see 2 small rectangular holes. I used two small screwdrivers, one to create a gap the other to prise the unit apart, when u are able to get your fingers in gently separate both parts from bottom to top.
You'll notice where the rubber pads meet the contacts there is 'condensation' this is what causes some of your remote buttons to fail.
Simply wipe away with a clean damp cloth, dry off, clip the remote together again and you basically have a new remote control.
1helpful
Dear sir, I have a Original Sony Remote Control and the model number is "SONY RM-892". I would like to know how can i open the remote control and to clean up the dirt inside the remote...
Most of the remotes can be opened and cleaned but with care. These remote boxes are self fitting plastics locks and so you need to use a thin blunt knife to wedge open the sides, like removing the car tyre from the rim.
once open you can use a remote control repair kit to clean or form the carbon contact points.
please find tips from the link below:
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
13helpful
3answers
TV remote RM-ED002 for main TV works fine except volume control which has no effect. Another Sony remote, RM-ED007 for second TV works fine on main TV including volume control.
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
