SOURCE: Karcher K3.92 M 1750 PSI
They are sensitive to large extention cords. My father in laws pops reset when a small cord is used. If internally shorted- motor will continually pop the reset even plugged direct to outlet. Check voltage at outlet.
SOURCE: karcher k2 power washer inlet-outlet manifold cracked along weld
well depends did u use it in cold tempatures if so no it was u. if not then most likely or could have been just a crazzy thought here that there was a electrical discharge when it was pluged in and cracked the block on it but honestly thats 1/10000000000000 chance of happening. or it overheated and cracked it but relistically if its new then just take it back and play dumb or if its still under warrenty play dumb and get it fixed. aslo u can search for a new part on craigslist or ebay. last but not least if its not uner warrenty or new to take back or u cant find a part either thru the ones i listed or by calling the man. ur last resort is to just throw it away.
SOURCE: Karcher B402 pressure washer Motor runs as soon
bob I had this happen to my Karcher, the pressure seals have blown. $Au200 for service and replacement from karcher dealer. tyhey would not sell the parts for a DFY
SOURCE: i need to replace the high pressure outlet on a k2-26m elecreic
if you contact Karcher they will tell you where your nearest supplier is located. try this link.
http://www.karcher.com/int/contact.htm
Testimonial: "thanks much, will contact them."
SOURCE: Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Testimonial: "Thanks brobin, your advice was spot on and it is now working again, much appreciated"
