Question about Jacuzzi Home
My Jacuzzi toilet is making a foghorn sound after flushing. I read in FAQ to close the fill valve slightly but I don't know how to do this. Please help.
  • 3,455 Answers
IF there is a valve on the water line in the toilet close this off it should turn clockwise to slow down the pressure
Posted on Jul 12, 2017
SOURCE:
  • 6 Answers
SOURCE: Toilet will not fill up
Some Toto fill valves have a plastic debris screen located at the inlet connection. Turn off the supply valve and remove the supply connection at the bottom of the tank. Use a mirror to inspect the screen for debris.
I agree w/ Smithbrother, the Fluidmaster fill valves are cheap and work well. The only thing they ever need is an occasional seal for $1.50 and 5 minutes to replace.
Posted on Mar 14, 2009
  • 687 Answers
SOURCE: valve in dometic vt2500 toilet won't close
You might want to try and lubricate the rubber gasket with some silicone grease or plumbers grease. If that doesn't work, follow this link. I'm sure there is information for your toilet at the Dometic website. http://www.dometic.com/enus/Americas/USA/Customer-Support/
Posted on Mar 20, 2009
  • 50 Answers
SOURCE: When flushed, the toilet (sounds like a lite scream)
try to replace the fluidmaster it is either that or your supply line is kinked,that or check the little black hose inside the toilet tank make sure that hose is not kinked,if neither hose is kinked replace the fluidmaster
Posted on Mar 12, 2010
  • 349 Answers
SOURCE: Need a flush valve / float assembly for my one
1-800-891-0896 http://www.efaucets.com/f/jacuzzi-ez33-959.shtml
Check this web site out I hope it will help.
Posted on Jun 05, 2010
  • 349 Answers
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Posted on Jun 10, 2010
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
When I flush my toilet I get a Foghorn sound for a few seconds what causes this ?
sounds like its the water rushing in to refill the tank try closing the fill valve just slightly to slow the water down
Apr 27, 2015 | Home
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Aug 30, 2014 | Jacuzzi Perfecta White Round 2-Piece...
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
My jacuzzi toilet doesnt fill with enought water in the bowl to remove waste from porcilin when flushing
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
Jan 29, 2011 | Jacuzzi Bath Era BK37 959 White toilet...
We have a Jacuzzi X532 toilet. Can't get the water to stop running into the bowl, causing excess water usuage and stains intoilet bowl. This started about two weeks ago. Have this toilet approx. 3-4...
I am not familiar with the model of toilet that you have, but many toilets suffer the same problem. It is usually due to the toilet cistern over-filling, as the water running into the bowl is the safety-overflow mechanism. The overfilling can be for a few reasons. The most common is that the fill valve is being held open, either due to mal-adjustment, or due to it being postioned slightly wrongly so that it hits either the side of the cistern or another part of the mechanism and can't close off properly. If you lift off the top of the cistern and watch what happens when the flush goes, you might be able to spot what is preventing the valve from shutting off entirely, and solve it. Hope this helps! :)
Jul 19, 2010 | Jacuzzi Home
High pitch shrill when flushing
I had the same thing happen to my toilet. The quickest way to resolve the issue is to replace the fill valve.
Jun 15, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
After flushing, the tank takes ten minutes to fill to a level to allow flushing again
Sounds like flush valve needs to be replaced , more then likely just ful lof lime deposits and it makes it slow to fill
Dec 26, 2009 | Jacuzzi Home
Tank won't fill unless I push down on flush valve inside toilet
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
Sep 13, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
Home Logo
50 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
