Question about Precor Exercise & Fitness
My precor doesn't have a numerical keypad, how do I enter the 1234 safety code
5 Suggested Answers
SOURCE:
prettynails4
  • 283 Answers
SOURCE: My HTC touch viva doesn't work. it was frm dubai.
You will need contact your service provider to get the subsidy unlock code to use your phone internationally or on another wireless carrier. They can walk you through how to enter the code in properly. It is free of charge.
Posted on Mar 17, 2010
SOURCE: pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Posted on Mar 27, 2010
avinash37
  • 91 Answers
SOURCE: i can put automatic keypad
this feature not available on sonyericsson phones
Posted on Jun 01, 2011
ercupa190
  • 12223 Answers
SOURCE: precor safety switch
Dear Sir:
Since this is the c.breaker.You must replace it.
The reason is mechanismo inside is broken, for that fact is faulty.
Proceed with the same model+amper+voltage: Please do not replace by other model with distint voltage+ amper+ model.
Disconnect the power cord before to replace, you must find in any radio schack, or computer, or hardware. sincerely G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA
Posted on Dec 05, 2011
I get a error 05 code on my precor treadmill C932/C964
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 05, 2014 | Precor 932i Treadmill
Corrective Action
ER 05 displayed on precor 9.31?
Corrective Action
Nov 23, 2013 | Precor Exercise & Fitness
Precor EFX 546 05 stuck key
Corrective Action
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
Error code 05 appeared on screen. We have tried to reset. Hit stop, enter, & quickstart buttons as decscribed. We also tried the reset button. The error code remains. We unplugged and tried again, but...
Corrective Action
Apr 11, 2011 | Precor 933 Premium Series Treadmill
Secret keypad letters in computer
hi
Click on a text box or open a text document.
  • 2 Press the "Num Lock" key to activate your keyboard's numeric keypad.
  • 3 Press and hold the "Alt" key.
  • 4 Enter the numeric code on the number pad. Press "1" to create a "smiley face." Display a musical note by pressing "14". To make a heart symbol, press "3".
  • 5 Release the "Alt" key after entering each numeric code. The symbol will appear.
  • Jan 15, 2011 | Computers & Internet
    My HTC touch viva doesn't work. it was frm dubai. but as i open it here in the philippines, all it display are the numeric keypad, asking me to enter a password to unlock it and says that only emergency...
    Mar 16, 2010 | HTC Touch Viva Cell Phone
    C470
    this is a fuser unit error code. reset code in following way.
    1, turn off power. 2, hold down 0 & 8 keys. 3, turn on power still holding keys down until beep is heard. 4, enter 400 on numeric keypad. 5,press start button. 6,enter 0 on numeric keypad. 7,press enter icon on the main lcd display.8,cycle power
    Oct 05, 2009 | Toshiba e-Studio 350 Copier
    How to unlock the keypad of blackberry 8310 curve?
    There isn't a way to disable the password of the BlackBerry device without actually knowing the password. Sorry. What will happen is if you enter the incorrect password 10 times the device will wipe itself, and clear the password. Of course, all data will be lost unless you have a backup of it.
    Oct 05, 2008 | RIM BlackBerry 8700c Cellular Phone
    Cell phone slvr l7 motorola
    codes & passwords
    Your phone’s 4-digit unlock code is originally set to 1234.
    The 6-digit security code is originally set to 000000.
    If your service provider didn’t change these codes, you should change them:
    Find it: Press - > Settings > Security > New Passwords
    If you forget your unlock code: At the Enter Unlock Code prompt,
    try entering 1234 or the last four digits of your phone number. If that doesn’t work, press - and enter your 6-digit security code instead.
    If you forget other codes: If you forget your security code, SIM PIN code, PIN2 code, or call barring password, contact your service provider.
    Apr 14, 2008 | Motorola Mobility SLVR L7 Cellular Phone
    Exercise & Fitness Logo
    Top Precor Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Tom Chichester
    Bill Boyd
    Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
