Stoves 12 in. (1248-1100) Electric Cooktop Logo
Posted on Jul 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant get food stains removed from top of stove i use a special cleaner and a special scrub and it still doesnt come off. it can be any kind of stain. the new stove tops are very hard to clean. any help would be appreciated. thanks
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Jul 27, 2009
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801829
Points
33142
I recommend a product called of all things "barkeepers friend". It comes in a can with holes in the top to sprinkle the powder out of.
Moisten the stubborn area and sprinkle this product on the stain then add enough water to make a paste. Make sure the paste covers the entire stain. LET IT SIT FOR AT LEAST TEN MINUTES. Then rub with a wet cloth. It always works for me and I have a black stove.
Burner stains Hot cookie sheet accidently set on
abrasive cooker cleaner. and pad. should clean it off. give it a good scrub.
We have an older corning cook top and it seems to burn or stain very easily. What is the best cleaner to use without scratching the surface.
I use a razor blade scraper to remove the heaviest deposits and then scrub it clean with Bar Keeper Friend cleaner.
3helpful
2answers
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Have a kitchenaid gas cook top with the flat cooking surface in the middle for griddling. But its all dark brown and discolored especially around the back. I cant see to get it clean or get the brown...
    A few cycles in the dishwasher may help. Oven cleaner on the surfaces (pre warmed if possible). Please do NOT use anything abrasive (no metal scrubs, no steel wool, etc.). Ceramic surface cleaner (Ceramibright?) can be used safely.
    Oct 12, 2009 • Cooktops
    Has anyone figured out a way to remove the dark stains that you can't get out on the ceramic top with the recommended cleaners?
    no any kind of chemical u can use to remove the stain,coz its normal for ceramic hob cooker coz of pots n pons every time u use.
    2helpful
    Puiter stain on stove top
    ITS NORMAL FOR GLASS CERAMIC, NO KIND OF CHEMICAL TO CLEAN.
    TNX GERBEE
    Stains on black cermaic oven top
    Use DeBruce Polish I guarantee great results, also perfect on stainless steel go to debrucepolish.com
    Can't get top clean
    there are a number of ceramic cooktop cleaners on the market, just like waxing a car apply with small circular motions, until it dries to a haze then remove the same way. stubborn stains can be removess with a razor blade (provided you keed the razor flat) do not use the corner of razor
    Dec 21, 2008 • Cooktops
    2helpful
    2answers
    Cleaning glass cooktop surface
    I used Mr. Clean multi-surface and the green, back side of the sponge. Turned on a light to show visible stains better, and scrubbed away. It didn't scratch the glass and got it out quick. Hope this helps.
    39helpful
    2answers
    Cleaning Thermador Cooktop?
    To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
    Top Stoves Cooktops Experts
    Paul Carew
    ADMIN Andrew
    ADMIN Andrew
    Are you a Stoves Cooktop Expert? Answer questions, earn points and help others
