Radio model M445SC01TG-AAT
I know of no such reset on a car radio.
Thank you. Hopefully disconnecting battery over night will solve the problem. will find out shortly, again Thanks for response.
Up Date-- disconnecting battery over night did the job, now works fine again.
That's not resetting, you just erased all user inputed data.
SOURCE: Hyundai Azera radio will not pickup AM dealer
Try it with the engine not running. If it works fine, the problem is RF interference. If you are using platinum spark plugs instead of the old copper resistor plugs, it can cause this.
SOURCE: 2008 Hyundai Azera XM radio "not ready"
I had the same problem. My 2008 Hyundai Azera had 37,800 and my wife went over a speed bump the XM radio went off and displayed "Not Ready". I raised the hood, pulled the negative battery cable for about a minute, replaced it and fixed the problem. Only issue is, this happens every couple of days. I'll probably continue to do this till my xm subscription runs out then to heck with it.
SOURCE: hyundai azera how to replace brake rotors 2007
This procedure is pretty common with all cars.installation is reversal of the above procedure and dont forget to lock your center wheel nut .
SOURCE: went to start my 2007 hyundai azera would not
check the battery cables, the clock reset indicates you lost power to the whole electrical system.
SOURCE: 2007 hyundai azera how to replace fog light
You have to turn the right or left wheel inside "whichever fog lamp needs replacing" and the light housing should be exposed on front of wheel housing.
