SOURCE: can I replace delta faucet t2710 with Delta SBS 84010BN ?
yes . when buying the faucet dont forget to buy stainless steel suply lines for water line connection.
SOURCE: Faucet and shower head leaking
Is it a single handle faucet set? If so it sounds like you need to replace the stem in the faucet itself. You can get to this with a screw driver and a pair of pliers. Turn off the water to the faucet (hot and cold) and remove the handle. Once you do this you will see a clip that hols the stem in place.Remove this clip and pull the stem out with the pliers and you can find a replacement at your local Lowe's, Home Depot, etc. Pay attention to the directions when reinstalling. there is a tab that determines the top side of the stem.
SOURCE: DELTA SINGLE HANDLE GOURMET SPRAY faucet
Hello. Actually it is not difficult to remove the faucet. If you can pull up the sink with faucet attached it will be very easy. Otherwise get under the sink with a flashlight and you will see what tools are needed. A special extendable faucet wrench from Home Depot would come in very handy. Regards. Joe
