Question about Kawasaki Engines NEW 17HP KAWASAKI ENGINE FH541V-ES31-S REPLACE BRIGGS KOHLER ZERO TURN
Kawasaki FH451V Engine on Gravely Zero Turn / Gas in Oil / Oil pushing back out Carb and (at least one, right side) Valve Cover
Left Side Valve Cover did not pour out oil like the right did, sitting a little off level though when removed. History: Cut grass a couple of weeks back, no problems noted. Went to crank today and was slow turning over (suspected only a weak battery to begin with) - put a jump starter thing on it and turned slowly, then cranked. Died after a few seconds. Tried again, same issue. Suspected a fuel issue (had problems when I bought it from Ethanol gum, but fixed and run Ethanol Free and Treated fuel ever since - caused Push Rods to drop out from stuck valves before). Anyway - noticed oil dripping from rear, then took off air filter and oil POURED out. Removed dipstick and looked down, Oil/Gas mix was pushed all the way up the tube - bubbly. Removed right side Valve Cover and oil / gas mix POURED out. Removed Left side Valve Cover - nothing really. Turned motor over very slowly, more oil and gas mix surges out right side but not the left. I am thinking broken / failed Rings on Right Side Piston or Busted Right Side Piston. Perhaps the engine keeled over after a short run because of Oil Pressure Drop / Switch working as designed? Thoughts?
    Champion:
  • 236 Answers
Your carb is flooding,fuel is going up your inlet manifold past the valves into the sump. It will come out of one side as the cylinder is higher on one side than the other. Drain and flush out the engine oil. Remove carb, strip and clean. Check fuel valve is clean and in good condition
Posted on Jan 23, 2019
SOURCE:
I just bought an old John Deere 68 riding mower but it does not cut grass even though the blade spins when engaged. I made sure the blade was on correctly but it still doesn't cut. I noticed the pulley...
Are you sure it is the correct blade and when it is turning the sharp edge is on the leading side? A spinning blade will cut grass even if the blade is dull. Did you lower the deck to the correct level?
Jun 28, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Where do you add oil
Look on the right side where the oil level site glass is. There is a chrome cover to the left of that which is held on by two bolts. You have to remove that cover to add oil. Ride your bike for a few minutes to get the oil warm,it's NOT a good idea to let it just sit there running since its air cooled. Shut it off and let it sit for a little to allow the oil to run back down; then make sure the bike is level when you check the site glass. A mechanics mirror, or someone sitting on the bike holding it upright is helpful. Do NOT go over the full line ,just below it won't hurt. It holds just over 4 quarts .
Apr 06, 2014 | 2001 Suzuki VL 1500 Intruder LC
Toro 22inch recycler mower Cut the lawn fine last week (wet grass) This week very hard to pull the pull cord Too tight to pull fast enough to start engine Any ides?
hi there
have you checked and removed any built up grass/ mudd from the blade/ bell housing ?
does the blade turn freely after this ?
remove the pull start cover assy does the engine rotate freely ?
make sure the blade brake is not stuck on ( if these units use them )
if no check your oil level ?
if you have no oil reading on the dip stick you could quite possibly have siezed or partially siezed your engine
make sure you have not hydraulicd oil into the combustion chamber ( this raises compression )
to the point where it has too much compression and oil will not compress and causes a loc near tdc
take look and let me know
cheers pauly46
May 27, 2011 | Garden
The oil change light is on steadily despite changing of oil a couple of weeks ago
remove the little cover from the combination meter and push the little button with a small screw driver its on the dash on the left side of the cluster. heres a pis to help guide you. hope this helpsonetufshoppe_57.gif
Jan 27, 2011 | 1994 Toyota Previa
Oil leak on the left side of engine
did you replace gasket at same time some vehicles or gaskets also requre gasket cement did you perhaps over tighten or under tighten covers
Dec 23, 2009 | 1990 Toyota Pickup
Head Gasket?? Valve cover Gasket???
most likely it is the valve cover gasket. it covers the valve train where there is alot of oil to lube the top of the motor. if the head gasket was leaking it may have more signs of running poorly. also having coolant leaks also. so i will have to say valve cover gasket. now usally you may have a oil burning smell with it depending on the area of the lek but not always.
the valve cover can easily be seen when the hood is open. it is right on the top and where it meets the clyinder head is where the gasket is and the leak can be seen.
if you have more question please ask.
Nov 12, 2009 | 1997 Geo Tracker 2 Door
I have a 95 honda accord with the non vetec motor. I recently replaced the spark plugs and valve cover gasket. After driving a couple of days, i noticed oil coming out from the back of the valve cover...
the valve cover gasket may not be seated right if you remove the valve cover check the gasket 4 damage if so replace with new one and make sure if there is a grove for the gasket to sit in that it is in all the way round , applying a little gasket glue on the valve cover befor fitting the gasket can help to keep the gasket in place when you refit to the engine
Sep 05, 2009 | Honda Accord Cars & Trucks
Where is the oil filter on my yamaha V-star 1100
On the right side of the bike (right side when ou are sitting on it) just above the rear brake lever behind a small circular plate. remove the plate and the oil filter is inside (you will easily see it). Warning---on these bikes you have to drop the front exhaust header and right floor board in order to change the oil filter unless you install a after market oil filter relocation kit. If you plan on changing your own oil it is highly recommended to install this relocation kit.
Apr 25, 2009 | 2006 Yamaha V Star 1100 Classic
Oil leaking out of valve cover gasket
It is a Valve Cover Gasket. You can get a new one at any Auto Parts Store. To make this repair last longer, Do not get the Cheap one, Get a Felpro Gasket and it will Quadrupel the Gasket Life. Please Rate My Response! Thanks!
Jan 30, 2009 | 2001 Kia Sportage
Kawasaki Engines NEW 17HP KAWASAKI ENGINE FH541V-ES31-S REPLACE BRIGGS KOHLER ZERO TURN Logo
119 people viewed this question
Top Kawasaki Engines Garden Experts
Clyde Ottaway
Neil Hancock
Are you a Kawasaki Engines Garden Expert? Answer questions, earn points and help others
