Read this article from field and stream about setting up tents.
https://goneoutdoors.com/quest-tent-instructions-7639684.html
SOURCE: No Instructions
Peg out the "brown" ground sheet of the inner tent and hold it up like a standard ridge tent.
Put the two shorter upright poles on the inside of the compartment (with something under the feet to prevent damage to the ground sheet). Put the 40mm tubes on the spike that pokes through, and then put the ridge pole on the outside.
Everything should then hold in place while you put the fly sheet over the top with the 2 longer poles at the front.......
tip - line up the seam on the fly sheet with the front of the inner tent as you peg it out....
Good luck
SOURCE: Wenzel Monarch Tent instructions
Wenzel does. They e-mailed me one for a different model that I bought on eBay. They're website doesn't offer any help but they were very helpful when I called!
1-800-325-8368
SOURCE: im looking manual instructions for coleman Sahara tent
Go on youtube, you will find some excellent videos on how to....on a range of tents. I saw the coleman sahara tent on a video last year as I was considering buying one! Good luck!
SOURCE: Instruction to put up a Coleman Rock Springs 4 Tent please?
Wow, thats a monster tent. I'll get you most of the way there, but I may miss a thing or two
Lay it down, stretch it out and peg it. That will save you a ton of time.
Next, find the four longest poles. These are the supports. Two on each side of the door, crossing diagonally to the rear. Put one end of the poles in the holes and bend until you can get the other end in. These poles should slide through sleeves in the tent. Once these are up, the rest are "extras." The tent has hooks to hold the poles to the tent.
You have two poles of equal lengths for the side windows. Again, route them thru a sleeve, bending them into the holes on either side of the windows. I can't tell, but it looks like you have a pole system for the front door too. Somehow these poles go next to the main support poles and meet up under the rain cover.
Next, lay the rain cover on top of the tent. It should connect by bungies to the bottom of the pole support holes. There might be a pole or two under the rain cover, but above the tent for support. If so. look for a small pouch that a pole could slide into on the bottom side of the rain cover. You'll run the pole from the pouch to another pouch (all under the rain cover).
Don't worry about strings or extra poles. These are for high wind. Pegging the tent down is good enough.
Good luck
SOURCE: where can i get assembly instructions for great outdoor tent
You can get instructions for Great outdoor tents if their not too old from Great Outdoors Hastings
