SOURCE: Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
SOURCE: cdc266 tumble dryer
hi you have to clean the inside of the machine I.E. remove the drum and on the back of the machine there are two heat sensors, the ceramic sensor is possibly faulty and needs replaceing
SOURCE: Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
SOURCE: my tumble drier dont heat up. It works but its
there will be a red overheat switch on the rear on most models, simply pull the machine out and press reset, the most cpmmon cause is running when empty or a build up of lint. if the doesnt work then it will be an open circuit element.
