SOURCE: I have a Jacuzzi Jet Pump Model 7C-S/B. Not Working
Check the breaker that supplies power to the unit. If it is in tripped position, check if the motor is grounded ( continuity between terminals and motor body), check for shorted windings (infinity resistance value between the winding phases), and finally check if the pump is stuck up due to debris or defective motor or pump bearings.
SOURCE: Jacuzzi jet pump doesn't produce much bubbles
A broken jet internal would allow water to run back up the air lines and contaminate the air lines on all jets that are on the same manifold allowing no air to incorperate into the jets stream resulting in low pressure
SOURCE: whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
SOURCE: I NEED DIAGRAM FOR JACUZZI MODEL U640 536 I HAVE
There is a small nipple on the back of the pump or the black box on top of the pump. This is where the tube attaches from the switch.
SOURCE: I need the manual for
Use this link to request a manual:
http://www.jacuzzihottubs.com/contact/support.html
Click the box to have the material e-mailed to you (faster) after you type in your manual request.
Or call them using this number:
1-866-234-7727
Thanks for choosing FixYa,
Kelly
