What sort of pies? Meat? fruit?
What temperature?
These can alter the answer, but if being kept at a temperature at which bacteria cannot grow, (i.e. HOT) then from a health risk point of view, reasonably long, however, the actual pie will deteriorate due to desiccation - the liquid will dry out and the pie go hard and unpleasant.
If being kept at a warm temperature, the risk to health can increase quite quickly, as bacteria start to multiply and cause serious problems. The pie however, will stay apparently edible for longer.
I would not leave anything in a warm place for more than 4 hours and the hot place, whilst not getting full of bugs, a similar time as it will be drying out by then.
SOURCE: ABOUT MSchart pie code
This link will provide you a sample Pie Chart code using Visual Basic:
http://www.chestysoft.com/xgraph/demopie.asp
SOURCE: 3D Extrude and Bevel in Illustrator CS 3
Chances are you have chosen 'stroke' color as 'blank/empty' in the first pie chart, and 'stroke' color as 'black' in subsequent charts, by mistake. So as a result the charts are having a black outline. You simply have to select 'stroke' or 'outline' color as blank as you did in the first chart. Colors can be chosen in the 'swatches' palette, either for 'fill' or 'stroke' or both. Hope this solves the problem.
SOURCE: burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
SOURCE: how do I use the pie function on a TI-36x calculater
The "pi" function is the number 3.141 and is used is various formulas. You simply push the pi button to bring up the number
SOURCE: Microwave still runs but is not cooking food
Sounds like a bad magnetron, i would replace the magnetron, Capacitor and Diode at the mag assembly, to be honest it will cost you more to fix than a new one.............
