I HAVE A NEW DISH NETWORK HOPPER I CAN'T PROGRAM THE REMOTE BECAUSE I CAN'T GET A PAIRING CODE WHAT CAN I DO
SOURCE: Remote code for Sony Home Theater
Here's a link to the user manual for the remote. There's a section with codes for programming your devices.. Also, it says, if code isn't listed, there is a "code search" function on the remote..
SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
SOURCE: Dish Network 5.0 IR Remote Sony DAV-HDX275
The code for the 6.3 ir/uhf pro remote when set to uhf is 794. Fist hold down aux until all lights blink then press 2 then enter 794 and press #.
SOURCE: need to program 311w U. remote to RTD215 home theatre
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
SOURCE: can't find a code to
We would be happy to help with that. Here is a list of someof the codes that we have for RCA home theater systems: 703, 852, 772, 638, 704, and 727.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codesfor your RCA home theater system provided above. Press the pound (#) button, the modelight should flash three times. Checkthat the code works by trying several different functions on the remote to makesure it will properly operate your RCA home theater system. Keep in mind that some codesmay not be compatible with your equipment. If this is the case, please try theother codes listed for that device until you find one that is compatible withyour equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
You miss understood I'm trying to program the Dish remote to the stereo
