Coffee Makers & Espresso Machines Logo
My Rancilio Slivia is heating the water in the reservoir when it is on. Warm water returns from the boiler via the return tube to the reservoir. Is there something I can do about it?
The machine is about 5-6 years old and is used pretty regularly by several people in my group. When were more people, it;d probably do 10 double espressos daily during the week. Otherwise, we run demineralized water in it, and keep the group head gasket fresh. We tend to run fine grinds and pull ~30 second shots for a double. THis happens even if the machine has not been used all day, but was turned on.
5 Related Answers
z34aga
Sulejman Sulejmani
  • 138 Answers
  • Posted on Mar 30, 2009
SOURCE: Rancilio Silvia Espresso water flows too quickly about 7 seconds
  1. check the coffe filter>> it could be teard up and leaking(check it carefuly it is hard to see sometimes)
  2. check the pressure you get from group. 7 - 9 bar pressure you should get to handle. if it is biger than check by pas valve and adjust the pressure, also check up boiler security valve(security valve for water for coffee)
Anonymous
  • 1089 Answers
  • Posted on Oct 23, 2009
SOURCE: Rancilio Silvia leaks around group head. Gasket seems fine.
HI
You need to change the group head gasket. They only last about 1 year and then should be changed. Get 2 because they usually fail on Friday and you have a party on Saturday.
The gaskets get hard from the heat and don't form to the filter any more so they leak.
When you get the new gasket.
Empty everything out of the machine (water tank, drip tray, etc.) Turn the machine upside down on a towel. This way you can see what your are doing.
Remove the filter screen and diffuser from the brew head. The black O-ring is your gasket. Carefully pry it out. Clean the opening good before you install the new gasket. Insert the gasket with the beveled side down (on the inside edge of the O-ring is the bevel). Once you have the gasket in place, use the portafilter to finish seating the gasket.
Anonymous
  • 1089 Answers
  • Posted on Jan 09, 2010
SOURCE: The frother does not work
Hi
If you can get water from the wand with the middle switch, you have a bad steam thermostat. Its on top of the boiler and its the one that doesn't have the red dot on it. Replace the thermostat and you should be back in business.
Anonymous
  • 1089 Answers
  • Posted on Sep 11, 2010
SOURCE: I have a (nearly) 3
Your 3 way valve is stuck. Its the panel behind the brew head. Slides to the right only.
nojimon
  • 5 Answers
  • Posted on Jan 11, 2014
SOURCE: I have a Rancilio Classe
i agree you need to measure the amounts of water comming out of each head with no coffee in the basket measure and if uneven reprogram both with identical size grind
Descaling rancilio
Use Citric Acid.
  1. Dissolve about one tablespoon of citric acid in the water reservoir.
  2. Fill the boiler completely. Open the steam valve and start a hot water cycle until water comes out the steam vent. Stop the hot water cycle, close the vent.
  3. Let the boiler heat up about 5 minutes. Then turn off the power.
  4. Let the acid solution work for about 1/2 hour.
  5. Pull a 30 second shot to change the water in the boiler.
  6. Repeat flushing cycles (steps 3, 4, & 5) until the water looks clear. Refill the reservoir with water and acid as needed.
  7. Wash out the water reservoir.
  8. Pull 5 or shots to get the acidic water out of the boiler. Run a hot water cycle to clean the acidic water out of the steam vent.
  9. Let the unit come to temperature and look for leaks.
  10. Make some coffee and look for leaks.
  11. Froth some milk and look for leaks.
I have a rancillio. The steamer works really well for about 15 seconds and then peters out???
Descale the boiler with citric acid.
  1. Turn off the machine and let it get cool
  2. Dissolve about a tablespoon of citric acid in the water reservoir.
  3. Turn on the machine and then pump about a cup of solution out of the boiler vent using the hot water switch.
  4. Turn off the switch. Close the vent
  5. Let the boiler heat up for about 5 minutes.
  6. Shut off the machine. Let the acid work for about 30 minutes.
  7. Check the level in the reservoir.
  8. Turn on the machine and then pump about a cup of solution out of the grouphead using the brew switch.
  9. Turn off the brew switch.
  10. Repeat steps 5,6, 7, 8, and 9 until the water runs clear.
  11. Wash out the reservoir.
  12. Turn the machine on. Pump a full reservoir water out the grouphead using the brew switch.
  13. Refill the reservoir.
  14. Have some coffee
2answers
Baxi duo-tec boiler - when water comes on flame roars up. When i put the heating on the flames roar for 5 minutes then die down.
is the boiler a combi if so have you checked the pressure. it needs to be at 1.5 bar 2 bar at the most . also check that the heat the boiler is producing is completeing the circuit on the heating if you have access to the pipe work there should be 2 or 3 22mm copper pipes. now turn the heating on and check which one is getting warm. the one that is is your flow and in about 2 to 3 min there should be one more pipe getting hot let me no if this is the case
SilviaWhen running wster thru group head to warm up machine, noticed foamy-smelly water. Ran more - now have almost black water with tiny black specs.?
You have huge corrosion and scale in the boiler. Your heating element will be fried soon. Boiler must be opened up and cleaned, element may be salvageable. USE ONLY BOTTLED WATER NEVER EVER TAP.
www.dolcevitaespresso.com
Water safety sensor preventing heat up of boiler?
If the red light is on then the machine is not getting water and or level is low in boiler. Try this remove the bell looking softener and run it under the faucet to see if water flows through, it could be that is blocked and not letting water through, and if so then the reset switch for element might have tripped because machine has low water.
1helpful
2answers
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
5helpful
Manual for Rancilio Silvia V3 (two water supply tubes - why ? )
Hi
The second one is your relief valve return water line. It just sets in the tank. Doesn't go anywhere.
8helpful
Not heating up the water
Hi
3 things could be wrong. First is easy to check. With machine on, turn on the steam switch and after about a minut open the steam knob and push the middle switch. Check the water coming from the wand and see if its warm? If it is you need a brew thermostat. Unplug the machine. Remove the water tank. Remove the 4 screws that hold the top on and lift top off. The boiler has 2 thermostats on the top front of the boiler, and the one with the red dot is the brew thermostat and need replacing.
If that didn't fix your problem there is a reset thermostat on the front face of the boiler and has black wires going to it. There is a red button in the middle of the thermostat and needs to be pushed.
If that one didn't solve your problem you need a new heating element. You can do a continuity check on the terminals.
Rancilio silva
Hmmm. It doesn't sound like a boiler problem. The heating element is controlled by a pressure or temperature switch. Either the switch is poorly connected or malfunctioning. Temp. switches are directly on the boiler with wires that go to a relay connected to the heating element. Pressure switches just have a tube connected to the boiler with wires to the relay.
Top Rancilio Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
