Question about Freezers
Can you reverse the door swing on a upright freezer. Frididaire model fffh17f1rwo
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 41 Answers
Hi Debbie,
I'm sorry, but I don't think so. There is a key that pops out when you lock it so I doubt the door can be reversed.
See page 8 of this manual under Optional Features and reversing the door swing is not listed.
On the positive side, it does have a high consumer satisfaction rate.
Happy 4th! :-)
Posted on Jul 05, 2017
SOURCE:
My Frididaire upright freezer is making occassional squealing and knocking sounds. model FFU14F5HWN. Any ideas?
Sounds like a compressor or a condensing fan motor. If it is the fan motor most of the local motor supply houses carry them.
Nov 01, 2014 | Freezers
My frigidaire automatic defrost upright freezer gets ice build-up at the top right at the front any suuggestions
This is just a general answer but it may mean that the door seal is leaking. Try running a dollar bill under the seal to see if that area is looser than the rest of the door seal.
Look inside the freezer for model number.
How to Check Freezer Door Seal DoItYourself com
Aug 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frididaire upright freezer shows OF code? How do I get the freezer to reset?
Unplug it for about 30 minutes and plug back in and see if this does it.
Sep 11, 2012 | Frigidaire 20.3 cu. ft. Upright Freezer...
Door does not stay sealed when closed.
first make sure there is nothing inside stopping the door from closing , the freezer should be level, and the door should swing close on its own free will. the door can be tweaked by bending it back into shape .or by setting the top hinge bracket, it should have three 5/16 bolts, that will alow you to ''square the door''. but most of the time it's something in the way of the door.. look close and remove some items that you think might be in the way, then remove some more
Aug 08, 2011 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Door swing
yes any door swing can be reversed.take a good look and you will see the screws covered up with plastic covers .the door has to be removed first but check it out and you will see its not a big job get everything ready and it can be done within 10 minutes.adrian,,,,
Jun 29, 2010 | True 19 cu. ft. / 538 liter Commercial...
I would like to remove the door,The door has two screws holding the hindge on what type of screw driver do I need
most upright freezers have a 3/8" screw to hold the hinge to the cabinet. most also do not allow you to reverse the door so are you wanting to do something else by removing the door?
Jan 03, 2010 | Freezers
Mu upright freezer door seal was loose and it is leaking from door would this cause domw food to thaw and can it be fixed
a leaking gasket can cause food to thaw and it can be fixed if a new gasket is avaliable from local appliance parts place..the gasket is held on by the liner which is removed by gently lifting the gasket and removing the screws..the reverse to install the new gasket
Sep 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
211 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
