Range, <<< seen where?
we cannot see what you see, here.
sorry.
wild guess transmission range fails on the cluster??????????
car drives ok, not told , job 1. yes/no.
well we scan the PCM (means OBD2 port on dash) scan TOOL.
and see why.?
causes are (but the error matters) DTC
1: lost comms from TCM to PCM and cluster brains.
2: transmission PRNDL switch fails but does car drive oK>?
3: wiring related to all that failing.
4: check fuses for blown?
Mar 6, 2013 - My wife told me that on occasion the headlights and the dash lights willblink when she lets off the. ... 2002 saturn l200 headlights and dash lights blinking.... 2000 LW2 dash lights Inop, spotts56, Saturn L Series Sedans & ...
My wagon 2003 l-300 has flickering lights and when the radio is off you can hear the ...My Dad has a 2002 Saturn Lw series wagon. the transmition has been ...
Aerial I take it you mean antenna ? If you hooked the pos (+ ) to the wire marked antenna then be sure that the antenna housing is grounded . Hope this helps
Found the same prob with a 2000 4x4.....Took the dash apart were the switch is,cleaned the contacts and it took care of it.. The 4 wheel drive worked fine just the light in the information box was a pain.....it was only a connection.....
That orange light means that you must have your braking system check...most probably it's the pads wear indicators that are earthing warning you that the pads are worn.
11= Timing belt skipped 1 tooth or more from initial learned value,
Intermittent loss of either camshaft or crankshaft position sensor, No
crank reference signal detected during engine cranking for dodge odb readout. Hope this helps.
