Display is half screen, after laptop dropped.
SOURCE: LCD screen on Dell laptop displaying unstable picture: a ribbonlike portion across bottom of screen
it looks like yourr lcd is broke down. because when you touch it looks normal.
SOURCE: I just replaced the LCD screen on a Dell laptop,
you may need to check the cable connection from your motherboard to the lcd which u can find under the plastic panel above the keyboard. towards the right of the power button u will find a small hold with which u can use ur finger to get the plastic panel out... under which u will find two screws for the keyboard.. unscrew them to see the connector and re-seat the cable.. it should work .. if it does not.. u'l have to get the lcd panel replaced again.. the lcd kit is faulty that means.
SOURCE: laptop display only displaying the top half of the screen
Test it with an external monitor if it works fine then you will need to replace your LCD screen.
