SOURCE: Panasonic microwave start button
You may have a sticky door switch. Try a simple "slamming" of the door, don't over do it, just a little harder than normal. This may help pop the plunger in the switch back up. The switch could have also become loose and moved out of its adjustment.
If this does not help, a technician should save you time and money with this sometimes perplexing problem.
SOURCE: How to replace keypad on LG Microwave
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
SOURCE: microwave will not cook..all the buttons work
hi..the reason to this problem may be due to one of these
reasons.check it out from the following link.
http://applianceparts.wordpress.com/2008/10/29/microwave-doesnt-heatcook-food-what-is-wrong/
try this out..
thank you..
kindly rate my response..
SOURCE: LG LMVM2075 Microwave Control panel does not work
The keypad has failed and it is available as a part of a new outer door panel,
whose part number is 383EW1A130E for $103.19 plus shipping.
You can get it from Encompass here
or you can call them toll-free at 866-779-5835.
For disassembly info, you can see the service manual at our site:
http://www.microwavedisplay.com/lmvm2075sb_sw_sm.pdf
It does not contain part numbers, so you will need to contact Encompass.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe
the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out
of the controls and door panels.
