SOURCE: forgotten administrator account password!
download this file burn it to a cd and boot from it.....select the directory whr your windows is installed
http://rapidshare.com/files/226200662/cd080802.zip
SOURCE: dell inspiron 1545 power on administrator password pro
You can get a Password Reset disc download and burn to CD. Copy/paste the address below, into your address bar of your browser.
http://pogostick.net/~pnh/ntpasswd/cd080802.zip
Download this file and burn it to CD. Put into drive and turn on PC, and boot from the CD. Follow instructions, choose the correct USER. & BLANK the password. make sure you say OK to write the data, and reboot. The logon password will now be reset blank.
SOURCE: My laptop window 7 Toshiba Satellite Pro L500 loss
try to find your hints. if you can not find so you must need to change window.
SOURCE: what is the administrator password for the hp lj pro 200 clr m276nw
You could go to the following site, and reply to "Jason_h", and request the solution. Maybe he will respond. Be sure to tell him what printer you have. http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/Laserjet-Pro-200-m276nw-lost-password/td-p/2408057 or try this... http://h30499.www3.hp.com/t5/Multifunction-and-All-in-One/HP-LaserJet-Pro-200-color-MFP-M276nw-Cold-reset/td-p/5957973#.U5nwB9IU__8
If you have forgotten your password if you have another user account with administrative privileges you can log into that account and change your original user accounts password from the User Accounts applet in Control Panel.
If you dont have another account like this set up or dont have the password to it you will need to log into the built-in Administrator account.
In XP Home boot the computer into Safe Mode.
Do this by repeatedly tapping the F8 key as the computer is starting up.
This will get you to the right menu
Navigate using your Up arrow key the mouse will not work here
Once in Safe Mode you will see the normally hidden Administrator account
The default password is a blank
In XP Pro you do not need to go into Safe Mode
At the Welcome Screen do Ctrl-Alt-Del twice to get the classic Windows logon box.
Type in "Administrator" and whatever password you assigned when you set up Windows.
If you reset the built-in Administrator accounts password in Home or have Pro and dont remember the password there are ways to change the password for that account to a blank
hope this helps
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password http://majorgeeks.com/Bios_d235.html http://majorgeeks.com/CmosPwd_d239.html hope this helps
also
When you boot up to the log in screen type in administrator as user to log in if you cant log in during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you can change the password there
Save, delete, and restore your BIOS settings
or http://majorgeeks.com/download.php?det=5710
you will have to burn it to a disk as an ISO
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
hope this helps
