SOURCE: Edit number stored in speed dial
all you need to do is push and hold the speed number button that you what to chang till it starts blinking in the display. i think the name comes up 1st. press enter if that's o.k. ore use the courser to delete. if you have pressed enter then the number show-es up press the arrow key back to erase @ enter the correct numbers. hit enter key. if you git in to something you don't know press the stop key 2 times will git you back to main screen
SOURCE: dialing presets
Hi John, you posted this a LONG time ago.. but I will add a sollution incase anyone needs to find out in future..
to add a number (i.e 01234567890)
1. Lift the handset
2. Press the 'STORE' key, then enter 01234567890
(the number will not be physically dialed - rather, the telephone is memorising it internally)
Press the 'STORE' key again after you enter the number
then select the button you wish to locate it to.
i.e : 'STORE' » enter telephone no. » 'STORE' » Press desired memory button..
Hope this helps
Kevin (In Dublin, Ireland)
SOURCE: Need to program numbers in speed dial (or replace lost manual).
If you go to the following webpage there is a link to the manual:
http://www.amazon.com/exec/obidos/ASIN/B00005NGRJ/plaza101-20/ref=nosim/
It is under the 'Product details' section. The section on managing the memory start on page 34.
To change a stored number you just follow the initial instructions, namely:
1. Press the STORE button. ENTER TEL. NO. is displayed.
2. Use the keypad to enter the phone number. If you
want to add spaces instead of dashes in the number,
it will dial correctly.
• To scroll forward or backward, use NEXT or
PREVIOUS.
• To erase the current digit, press ERASE.
3. When finished, press STORE. ENTER NAME is
displayed.
4. Use the keypad to store a name (up to 16 characters).
More than one letter or character is available in each
of the number keys. For example, to enter the letter
“A,” press the 2 key once. For a “B,” press the same
key twice. For a “C,” press it three times.
• To add a space, press NEXT.
PREVIOUS.
5. When finished, press STORE. MEMORY LOCATION is
displayed.
6. Press the memory location number (0-9 or A, B, C) to
store the number.
I hope this helps you.
SOURCE: I just got a samsung Shark GT-S3550. How do I use
samsung shark gt-s3550
there seems to be a problem with my phone,I am unable to view
messages, it just doesnt open the inbox at all. I have tried anything
else on the phone. Is there anythin
useful you can tell me?
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
TELEPHONE NUMBER
TEL =
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
• You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
• If a number is already stored at the button you select, that number appears.
• If the button you select is registered for Group Dialing, GROUP DIAL appears.
TELEPHONE NUMBER
TEL =
• Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
• If you want to clear a number or a mistaken entry, press CLEAR.
• To enter a pause in the number, press PAUSE one or more times
