Microsoft Windows Vista Home Basic with SP1 32-bit for System Builders - 3 pack for PC  Logo
Anonymous Posted on Jul 26, 2009
Vista x32 want to upgrade vista x64
Ok, so I have a Windows Vista x32, I know i know OMG VISTA, but I want to upgrade it to the 64 bit from the 32 bit. I am really good with computers (so it frustrating to have to ask) buit is there a way to upgrade it from the 32bit without much hastle?
A
Anonymous
Microsoft provides upgrade discs from it's site (you should payteh freight).
If u are using Microsoft Windows Vista Home Basic, there is no way to upgrading.
else, the other versions allows u to upgrade.
remember: the only difference between 32 and 64 bit is the RAM memory usage (32 bit will not use more than 3,2GB RAM), and there are a lot of programs that won't run properly in 64 bit version .
Network sharing center won't stay open
just been fixing a window vista laptop with problems
Microsoft stopped supporting windows vista years ago
no updates or upgrades
you are at base service pack one
and computer should have been updated to service pack 3 years ago
from service pack 3 a windows 10 upgrade is possible
try an ethernet or usb wifi connection .
.see if the computer will run the way you want it
any windows vista computer is a x32 bit system
with upgrades can run x64
x86 is the current
if you are running anything higher than 32 or x64 software the computer will be slow sometimes freeze or shut down
vista came out same time as and dial up internet
and early broad band
vista can run office 95 but windows 2000 is stable
Is the ensoniq mr61 compatible with windows 8? Is there a device or upgrade for this?
Supported Operating Systems and Hardware MQ Essen
tials
Midi
Quest
Midi
Quest
Pro
Info 32-bit Windows support: Win 8, Win 7, Vista, XP checkyes.png checkyes.png checkyes.png 64-bit Windows support: Win 8 x64, Win 7 x64, Vista x64, XP x64 checkyes.png checkyes.png checkyes.png Windows Midi Quest x64 with x64 plug-ins to support 64-bit VST hosts checkyes.png Intel Macintosh systems: OS X 10.9, 10.8, 10.7, 10.6 and 10.5
Check this link
2helpful
2answers
Lexmark 5400 series model no X5470 is not working with windows 7 ultimate . please give me a solution Amresh Mishra
First, unplug the Lexmark printer from your computer. Then uninstall any existing Lexmark X5470 driver from your computer. Go to Start menu -> Programs -> Lexmark X5400 Series -> Tools -> Uninstall. Uninstall the driver. Reboot pc when prompted.
When your computer turns on, check if your Windows 7 is running on 32-bit or 64-bit service type. Go to Start menu -> right-click on Computer -> Properties. Take note of the Service Type.
Visit the Lexmark website to download the Vista driver. Use the links below:
Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
1helpful
2answers
Can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
2helpful
2answers
System requirements of vista
For Vista Home Basic >>>
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
  • DVD-ROM drive
  • Audio Output
  • Internet access (fees may apply)
Additional requirements Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
For Vista Home Premium, Business and Ultimate >>>>>>
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics with:
    • WDDM Driver
    • 128 MB of graphics memory (minimum)
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • DVD-ROM drive
  • Audio Output
Home Premium / UltimateTV tuner card required for TV functionality (compatible remote control optional).
Home Premium / Business / UltimateWindows Tablet and Touch Technology requires a Tablet PC or a touch screen.
UltimateWindows BitLocker Drive Encryption requires a USB Flash Drive and a system with a TPM 1.2 chip.
Windows Vista minimum supported system requirements Home Basic / Home Premium / Business / Ultimate
  • 800 MHz processor and 512 MB of system memory
  • Support for Super VGA graphics
  • CD-ROM drive
Regards.
1helpful
3answers
Can i window vista install in 512mb ram?
Windows Vista recommended system requirementsWindows Vista Home Basic
Source: http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx
Same prob
Make sure you have the Vista 64 bit drivers installed. The 32 bit drivers are not the same. Hope this helps.
Windows vista
Appreciate the direct "Ask me" again and likewise the previous ratings.
To my knowledge, Vista x64 is just an x32 with 64 bit addressing. Some have reported that 64 bit on a Core 2 Duo isn't a very good idea with the extra speed gain of x64 over x86 being marginal for now. Offhand, you might be better off still with X32 at least for the time being.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
2answers
Conversion of 32 bit vista into 64 bit
You have to buy windows vista x64 bit version, or if it is included install x64 bit when the screen comes up and says:
Install x86
Install x64 <-- Choose this one
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
