Golf Logo
D
Dan Hodson Posted on Jul 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2000 yamaha electric carts is slow in forward fast in reverse. Has new forward and reverse switch. Why would cart have almost no power up hill but will fly up hill in reverse?
Ronald Prier
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Jul 03, 2017
Ronald Prier
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
145899
Points
158
Check the forward reverse switch, could be connected backwards.
EZGO golf cart will not go
It's possible that the motor, solenoid, or wiring has become disconnected or damaged. I recommend starting with a basic inspection of all the connections, wires, and components. If all looks alright, then you may need to have the motor and solenoid tested. If there is still no luck, then you may need to replace the EZGO golf cart motor or solenoid.
Jan 15, 2023 • Golf
What caused a 2011 Yamaha electric cart to stall and restart 2 hrs later. Over a 5 mile, I notice loss of power while going up hill and down hill
This power plant can be tested with a scanner, the dealer would need to do it, but guessing is a more costly route, have it tested.
1988 club car runs in reverse but not forward
If this is a 5 solenoid cart then I would look at the forward/reverse switch. Sometimes one of the copper contacts will get hot and melt the plastic around it, causing it to sink in and not make contact. I have seen this happen where the cart will move one way and not the other. Other times the contact is so burned, it will not make contact either direction. If the contact is burned then the only cure is a new f/r switch.
Sep 12, 2016 • Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 • Golf
Club electric golf carts
Resister coil pack....Look up Buggies Gone Wild. Tons of info.
Sep 08, 2013 • Golf
Top Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Golf Expert? Answer questions, earn points and help others
