Goes In a Nissan 15 hp outboard motor
SOURCE: tune up
There are two factors that can influence your decision: preference and budget. Most plugs on the market will perform satisfactary as long as the match the manufacturer's guidelines and are gapped correctly.
SOURCE: Does an 85 johnson outboard motor 15 hp have
breaker/maker. set @ 020" @ the highest point but what is you're real problem. Run only champion spark plugs. We spenta dAY @ omc'S SERVICE CENTRE BEING SHOWN WHY. tHEY KNOW BEST!!
SOURCE: I changed my 2001 passat
I had an instance when I had put a cheaper brand of plug in a Hondai Sonata instead of the plugs that the manufacture recommended and it picked up a slight hesitation.Im not saying that this is always going to fix every situation like this but if you didn't have this problem before you put the new plugs in then that would be the first place I would start.When you by your plugs they should already be gaped but always ask the auto parts store to provide the gap setting or look on the Vehicle Emissions Information Tag.This will provide all the info you need motor size, plug gap,and vacuum hose routing.Its usually located on the underside of the hood or on the radiator support right in front of the radiator
