SOURCE: forwarding e-mails from gmail account to yahoo account
You need to click on settings and click on forwarding and select Forward a copy of incoming mail to put in the email address you want to forward it to. This will resolve your issue.
Thank You
Regards
Nikhil Mahajan
SOURCE: requires the user to type thier user account and password
i have receive firewalll error in windows 2003 server this error is fallow
Due to an unidentified problem, windows cannot display windows firewall settings.
SOURCE: i have changed a new password for my administrator
Do you need to reset vista or xp users password? Ihas a little trick that dig it for you from tech-hack forums. The method is very easy to follow and doesn't require any complicated commands. The method is free to use and you don't need to pay hundreds of dollars for some utility for unlocking lost windows passwords. Just follow next simple steps:
First thing you need to do is to start command prompt or CMD. There is two ways to do that:
Press F8 when Windows XP start up (before windows xp logo - progress bar for loading) and choose "Save Mode Command prompt" option
If you are logged in: click on start -> Run, type "cmd" and press ENTER.
In command prompt window type command "net user" or "net users". You will see the list of users that are created on current running OS.
Type "net user" "user name" "*". You will see that windows will ask you to enter new password for that particular user account! No super user privileges needed. Just type new password two times and you are done.
Example of process: If the administrator username is "administrator" then command for changing its password will be: "net user administrator *".
Note: quotes (") in the post are just for highlighting the word.
SOURCE: How to Unlock Windows Vista Password?
I would like to introduce "Windows Login Recovery". It not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive to recover windows password. Booting up and clearing a password takes a minute or two works like a charm. You can download it from http://www.windowsloginrecovery.com
SOURCE: Suddenly I am having problems
OK you need to set up you account details again, it seems yours have been lost? corrupted or something. Anyway that error has to do with the actual email server, send receive settings.
Below is a How To Do it....
http://www.microsoft.com/windows/ie/ie6/using/howto/oe/setup.mspx
You need to put you Email server details as shown in the tutorial,if you don't know them simply Google for the info.
