Vacuums Logo
L
Lou long Posted on Jul 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My shampooed won't pick up ythe water - Vacuums
Dan Apthorp
Level 3:
  • Master 2,824 Answers
  • Posted on Jul 01, 2017
Dan Apthorp
Master
Level 3:
Answers
2824
Questions
0
Helped
889888
Points
7391
Does your shampooer have a cap on the shampoo tank. Usually you take the cap off to let the shampoo out while shampooing and to pick up the water you put the cap back on to create a vacuum to suck the water off the floor..
My kirby shampoo is not picking the water up
It is not supposed to pick up water. It creates a foam which you let dry and then vacuum up.
Is the Kirby shampooed supposed to pick up the water after shampooing
No. Shampooing is supposed to crystallize the dirt so you can vacuum it out. It is easy to leave to much soap residue.
2helpful
2answers
My Kirby shampooer wont foam
Start with the hose OFF the tank (make sure small filter is in place).Fill the tank with water and KIRBY DRY SHAMPOO (other shampoo's wont foam) then turn the vacuum on. At this time the shampoo will come out as a stream of foam. If the shampoo come's out as liquid then you will need to check the tank. If shampoo was left in the tank ,then the pick-up hose inside the tank my be colgged. These are hard to un-clogg so replacement of the tank may be needed.
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Wertheim w2550 carpet cleaner won't dispense shampoo
I just bathed my dog with sergeants skip-flea & tick shampoo with 0.10% permethrin and 0.50% piperonyl butoxide, technical. My dad then proceeded to almost immediately after apply another flea ...
Sep 07, 2012 • Vacuums
5helpful
I cant figure out how to **** up water with my kirby dimond
Vacuuming a wet carpet with your Kirby or any other vacuum not designed for wet pickup could do serious damage to your machine and there is a real danger of electrical shock to the operator.
Your Kirby Diamond and every other Kirby for that matter is NOT designed to pick up water!! Even with the shampoo system attached it will NOT pick up water or the shampoo foam. Your Kirby spreads the shampoo foam around on the carpet to clean it. You then only vacuum a shampooed carpet after it has completely dried.
How do you pick up the suds after shampooing
After dispensing the shampoo. You wait a few minutes. Then you turn 'off ' the shampoo picking the shampoo up. After the carpet is dry you pick up the rest. With the power head.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
