Model TD552
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
You saved my time by sharing this informative article because if you had not shared it I would be searching a lot about how to set touch screen clock. There are a lot of online casinos pennsylvania which really helps to get rid from stress and have some fun. Your ideas about innovation are fabulous.
SOURCE: ultronic lcd clock with a stylus tucked in back of clock
This thing set under my bed, lifeless til I was looking for something else and decided it was time to get this clock working!
(Use the stylus pen for best results) After putting in two fresh batteries (or hit the reset button if your batteries are fresh). This will reset the clock and the 'clock' icon in the upper lefthand corner will be blinking. Now press and hold the display area where the hour of the day is displayed. The entire time will start blinking. Now start tapping on the blinking hours to increment the clock slowly to the correct hours (it will cycle all the way thru military time and regular time, so choose what you desire). Press and hold with the stylus to increment quickly. Do the same with the minutes, that are blinking too. When time is correct, tap the 'clock' icon once. The 'clock' icon will still blink, which I believe is correct operation.
To set the date, tap on 3rd icon down from the top left (it looks like a little calendar). This will put you into the date section of the clock (if you do nothing, it will cycle back to the clock, after ten seconds, as a default). Before it cycles back to the clock, press and hold with the stylus pen right below the word 'DATE', until the the entire displayed date starts blinking. Tap the first two digits of the year to go down in years and tap the right two numbers of the year to go up in years. Tap on the month number to increment; do the same with the date number. When all date entries are correct, either tap the 'calendar' icon, or let the clock sit for ten seconds: it will cycle back to the clock.
I guess you can set the alarm in a similar method.
Hopes this helps!
ExitKC
SOURCE: Need to set an Ultronic clock
Press the time (current time - numbers) to get to the date mode. Then hold-press "SET" to set it.
SOURCE: ultronic WS-9 radio/clock/calculator is there a light?
need a manual for a Ultronic clock radio calculator model WS-9
